engine management
hi trouble magnets
i have an accent 1300cc 'x' reg with the management light lit on the dash can i remove the battery and reconnect after a while to extinguish faults and light? thanx in advance |
RE: engine management
you should be able too....just unplug the battery for 10-20 min and it should reset the ecu. but if there is a proble, expect the light to come back on.
sorry no on the later accents the fault is stored in the ecu and cannot be erased without the diagnostic equiptment.[&:]
