Error codes causing check engine light to be on
I am getting these two error codes causing check engine light to be on:-PO068 (MAP(MAF)-Throttle Position Sensor Correlation)
-PO505 (Idle Air Control System- Malfunction) Has anyone else had the same problem and been able to fix it? If so, how? |
