-   -   Exterior Door Handle 2007 Accent (https://www.hyundaiforum.com/forum/hyundai-accent-16/exterior-door-handle-2007-accent-10214/)
hpeteachny Jan 30, 2011 04:17 PM
Anyone know how to change the drivers side exterior handle. I removed the door panal but wasn't sure if I had to remove every thing else to put a new handle in. If anyone knows where I could find a step by step write up I would greatly appreciate it. Thank
NovaResource Jan 30, 2011 07:38 PM
DOOR TRIM REPLACEMENT
http://www.hmaservice.com/viewer/img/note_icon_eng.gif
- Take care not to scratch the door trim and other parts.
- Put on gloves to protect your hands.
1. After disconncting the connector(A), remove the quadrant inner cover(B).
http://www.hmaservice.com/data/Passe...G/bsje090a.gif
2. After loosen the inside handle cover mounting screw, remove the inside handle cover(A).
http://www.hmaservice.com/data/Passe...G/esng011a.gif
3. Loosen the door trim mounting screws. Disconnect the power window switch connector(A), power mirror connector(B). Remove the door trim(C).
http://www.hmaservice.com/data/Passe...G/esng012a.gif
4. Installation is the reverse of removal.
- Make sure of connectors is plugged in properly and each rod is connected securely.
- Make sure the door lock and opens properly.
OUTSIDE HANDLE REPLACEMENT
1. Remove front door trim.
2. Remove the door trim seal.
3. Remove the front door lower channel.
4. Disconnect the lock rod (A), out side handle rod (B).
5. Loosen the outside handle mounting bolts.
http://www.hmaservice.com/data/Passe...G/esng018a.gif
6. Push the outside handle base forward(D) and remove the outside handle(E).
http://www.hmaservice.com/data/Passe...G/usng080z.gif
7. Installation is the reverse of removal.
