Fuel filter for 2004 accent
Hello guy and gal,
I just wonder if you done this before,I need to change my fuel filter and filter was under the back seat. I was unable to find any bolt attached to the seat?
Thanks in advance.
Thanks in advance.
There are two bolts...on the outside...near the wheel well. You can access them by either folding the rear seats part way, or through the trunk after removing the carpet. You might want to double check. I believe a '04 doesn't have an in-line filter, it's part of the fuel pump.
I have a 2003/4 hyundai accent 1.6 with manual trans. It died the other week and I was stranded. I was driving down the road and it started bogging down all of a sudden even when i "padded" the gas peddle to try and keep it going. That seemed to help fir a bit. I turn around to start back home and then it "bogged" down and died so I had to get a tow home.
I replaced the crank sensor, coils and plugs. Checked the firing order. It starts but immediately dies and there is a "wisp" of tiny bit of smoke from the engine compartment. I turn the switch and can hear the fuel pump come on. I went to change the fuel filter and the fuel filter is not ontop of the tank like so many forums say it is.
Any ideas? I can keep it running long enough for my code reader....
Please help me!
Please help me!
2001accent
Sep 13, 2011 08:54 PM
