a/c problem
a/c problem
Hi Everyone-
I've got a 2004 Accent with an a/c problem. Basically, the a/c never shuts off! Even with the button showing it's off, the compressor still runs like it was turned on. The a/c starts running within a few seconds of starting the ignition, and the only way to stop it literally is to turn the engine off.
Has anyone seen this behavior before? Is it a short somewhere?
Any help would be much appreciated.
Thanks,
CH
Thanks,
CH
RE: a/c problem
Not so!
This is normal. The compressor will come on in DEF & DEF/FLOOR. When you disconnect the micro switch connector behind the heater control, then the AC operation is completely manual, and will only come on when you press the AC-button.
2004, 2005, ac, accent, air, airconditioner, compressor, conditioner, hyndai, hyundai, problem, problems, switch, thermister, working
