How can I remove inside door handle of 2002 Accent?
Hello everyone,
I have three broken outside door handles of my 2002 Accent. So I am trying to replace the handles, and have new door handle parts already. But the problem is that I really can't remove the inside door panel because of the inside door handle. (My car has power windows so it was easy to remove power window switch panel...) Can anybody help me? Thank you so much! - Jin |
remove the screw from the door handle thing, with the door panel loose, rotate the door panel and pass the door handle though the hole.
Be glad you have power window, getting manual window crank handle off the shaft is beyond a royal pain in backside, they did not put clip on handle in same fashion as the other 99% of makers to where you can slide std tool in and pop the clip out place to remove handle |
