Hyundai Accent Climate Controls
Hey everybody, I recently purchased a 2001 Hyundai Accent L (2D hatchback). I removed the center console to replace the radio and discovered why the climate controls weren't working, the center control **** (the one that allows you to choose where air blows from) is just spinning on the axis, it's not actually turning the gear in the back controlling the lever arm.
My question is, does anyone know if I can just find a new control **** or if I have to replace the entire OEM Climate Control's. I've found Climate Control systems on eBay but they all have the control arms in the back cut when they were removed. Will it be possible for me to use the one's from my current system with the new controls?
All I want is the ****, I don't want to have to buy a whole new control system!
Control ***** are available at the dealer. Make sure the cables are adjusted correct. The adjustments are clamps that hold the cable. One is located behind the glove box and the other on the driver side near the gas pedal on the evaporator case
