Hyundai Accent Spark no Injectors
Kids car no start will crank but will not startup. started at the plugs and found a spark, so I changed plugs just to make sure. checked at the pressure regulator there is fuel, I pulled the new plugs out of #1 and #2 and found no fuel in the cylinder. put a small amount of gas in cylinders and the car tried to start. so no fuel gets the cylinders. used niod light to check the pulse at injectors and got no lights at all on any injector. what is the next step? help
You did half the test with the noid lite.
With a simple test light, you must verify the injectors are getting power and ground. Check all the fuses, then verify ground is getting to the injectors when required. |
