Headlight question
Old 03-14-2013, 03:04 PM
lone ranger's Avatar
Default Headlight question
I have a 2001 Accent. Other day both lowbeams went out. When I switch to highbeams the lights work. So I figure to just change the bulbs. Well the lowbeams did not come on but the highbeams came on. Any ideas as to what the cause might be? I am hoping it is not in the stalk.
Old 03-14-2013, 03:42 PM
Chris Brook's Avatar
u could try the relay mite only be working on the high beam side
Old 03-15-2013, 03:59 PM
Thanks, I'll try that and give a report.
Old 03-16-2013, 05:54 PM
I checked for a headlight/light relay and I could not find one where the relays are located under the hood. The fuses that are designated for lights look good. So I am stumped.
Old 04-05-2013, 03:48 PM
Okay the low beams still do not work.
I've replaced the following in the hopes of making them work in the order that they were replaced:
Two new bulbs
Three fuess in the fuse box under the hood
One relay under the dash
One turn signal/light switch stalk
And still no low beam and all other functions work.
Is there a resistor that controls the current to the low beams or is that contained in the stalk?
Old 04-09-2013, 03:25 AM
zainecurtis's Avatar
If you have checked the fuses and relays and couldnt find anything..altho most all cars have a fuse for hi& lo beams but if they are both good get a voltmeter or continuity tester and check between the(giving that theres only one fuse) headlight fuse and the positive connection in the bulb socket. there should be three connections on the bulb . high low and ground (on turn signal bulbs the gound is the metal base of the bulb . if all is good you likely have a short circut in the switch somewhere in the console and when you turn on brights the lows shut off but a connection isnt being made to turn the highs on but the switch has been triggered so lows turn off. check out a wiring diagram for more info as to how your model works.
Old 04-09-2013, 03:27 AM
didnt notice * lows arent working . or your prior post ill see if i can get a wiring diagram since i have an 02 accent it should be the same
Old 04-09-2013, 03:34 AM
Default wiring diagram 02 accent headlights
FIRST two with drl third is with out ill try and send em to you but if dont get them send me your email and ill attach pdf pics
Jen
09-15-2006 03:48 PM
blckshark
08-18-2006 12:37 AM
00sonataGLS
05-19-2006 08:44 PM
Tweek
04-07-2006 02:28 AM
yangja
02-24-2006 02:18 AM
Quick Reply: Headlight question
