-   -   Lc with 7x17 rims is this a Problem (https://www.hyundaiforum.com/forum/hyundai-accent-16/lc-7x17-rims-problem-3718/)
Rik 11 Jan 18, 2008 06:57 AM
Hello,
i sholud to like ride my Accent with 7x17 rims and 195 or 205 wheels !
Please tell my is enough air to the mudguards ?
what must i change on the car body !?
I have this moment 7,5x 16rims with 195 wheels ?
are avaible Accent LC with 18 er rims ?
Can you show my Picture ?
fintile Jan 25, 2008 10:37 PM
RE: Lc with 7x17 rims is this a Problem
17's? wow...yeah anything bigger would not work, beside I have 16" rims and they look huge.
ken99 Jan 26, 2008 09:52 PM
What size tires are you running on the 16" rims? 195/??R16. You can likely move to a 17" rim, but the tire aspect ratio will need to be different to obtain the same rolling circumference.
I just looked up the spec's for an Accent. The original wheel was a 13" rim. I doubt you can buy a 17" tire that would be squat enough to match the original circumference. I wouldn't invest dollars into this unless you can confirm a 17" rim/tire combo can fit without rubbing in the wheel wells.
clintmeister Mar 29, 2008 08:48 PM
When I traded in my Honda Del Sol the dealer let me keep a set of universal rims that are 17X7 with 205 tires. They fit and don't rub on my 2008 Accent. But, these tires and rims are "heavy" and they have affected my mileage and power. I plan on getting some cool moon eyes disk hubcaps add some pinstriping and put them on the stock rim/tire combo. In the accessories catalog the factory offers a 17X7 with a 205 tire.
clintmeister Apr 9, 2008 02:09 PM
My bad, after reviewing I looked and my rims are 16 X 7. But I still have 205 tires.
It fills the wheel well quite well. Sorry.
Raiz Starwind Apr 15, 2008 10:00 PM
I just put 17's on mine. those are it in my sig. they do rub a little in larger dips at higher speeds in the back, but a little fender modding in the back should fix that i hope. i have also noticed a little bit of a rob in power and gas mileage, especially since having put a k&n cool air intake (which i highly reocmmend)on not too long ago increased my horse power and gas mileage
damn it seems i can't post a pic
