Looking for accent 2008 radio & speaker removal guide
As the title says, I've been looking for diagrams or guides to change the stock radio and speaker on my new Accent 2008 L Hatchback.
Any help would be appreciated! I've been looking all over! |
RE: Looking for accent 2008 radio & speaker removal guide
REPLACEMENT[/align][/align]FRONT SPEAKER
1. Remove the front door trim panel (Refer to the Body group - front door). 2. Remove the front speaker (A) after removing 4 screws. http://www.hmaservice.com/data/Passe...G/ltjf022b.gif 3. Installation is the reverse of removal. [/align][/align]REAR SPEAKER (3 Doors) 1. Remove the rear door trim panel (Refer to the Body group - rear door). 2. Remove the rear speaker (A) after removing 3 screws. http://www.hmaservice.com/data/Passe...G/ktnf022c.gif 3. Installation is the reverse of removal. [/align][/align]REAR SPEAKER (4 Doors) 1. Remove the rear seat (Refer to the Body group - rear seat). 2. Remove the rear package tray (Refer to the Body group - rear seat). 3. Remove the rear speaker (A) after removing 4 bolts. http://www.hmaservice.com/data/Passe...G/atjf022e.gif 4. Installation is the reverse of removal. [/align][/align]TWEETER SPEAKER 1. Remove the front door trim panel (Refer to the Body group - front door). 2. Remove the tweeter speaker after disconnecting the connector(A). http://www.hmaservice.com/data/Passe...G/ktnf022d.gif 3. Installation is the reverse of removal. [/align] |
Thx! but where do I refer for body groups?
Sorry about that:
REPLACEMENT DOOR TRIM REPLACEMENT [NOTE] - Take care not to scratch the door trim and other parts. - Put on gloves to protect your hands. 1. After disconncting the connector(A), remove the quadrant inner cover(B). http://www.hmaservice.com/data/Passe...G/bsje090a.gif 2. After loosen the inside handle cover mounting screw, remove the inside handle cover(A). http://www.hmaservice.com/data/Passe...G/esng011a.gif 3. Loosen the door trim mounting screws. Disconnect the power window switch connector(A), power mirror connector(B). Remove the door trim(C). http://www.hmaservice.com/data/Passe...G/esng012a.gif 4. Installation is the reverse of removal. [NOTE] - Make sure of connectors is plugged in properly and each rod is connected securely. - Make sure the door lock and opens properly. |
thx a lot! i found the wesite where you found the info.
QUite a daunting task, the center fascia doesnt get off with a wimple screwdriver.... |
Very helpfull info.
Any chance of a link to the website where the diagrams and info came from? |
