Lug nut torque
How much torque should I have on my lug nuts, for the 16" alloy wheel. I figure about 90?
You better take it someplace if you need a torque wrench to put on lug nuts. It's not rocket science.
Originally Posted by jsinton
(Post 22885)
Originally Posted by bigrob
(Post 22882)
90 lb-ft is too high in my opinion. I believe 65-80 lb-ft is what Hyundai calls for. |
(Post 22885)
Thanks Nova! I think your #'s may be a little low, but then again I am not sure, and thats whay I'm asking :) Just checked on Discount tires website, they show Hyundai's up to '05 65-80 lbs. You da man baby!! |
Ok then, I am humiliated for my meatball ways. Don't try to get a job at the tire shop and use a torque wrench though, you'll be a laughing stock.
(Post 22902)
(Post 22903)
Sorry but the brain-dead, ham-fisted gorillas at the tire shop are the laughing stock. I never let them touch my cars.
Anyway, I usually try to take my wheels off myself and bring them there, and then reinstall my self. That is what I did with these wheels and tires. |
(Post 22905)
I always go down the block and loosen and re-torque!! Nice to be sure!!
(Post 22905)
Discount tire ALWAYS uses a torque wrench after they have used the air gun! I am always on top of them watching. Problem is, their airgun settings are always higher than the recommended poundage, and when they use the torque wrench, it just clicks immediately and they think all is good, when in reality, they dont know! There could be 200 lbs!! They just know that there is AT LEAST what their wrenches are set at. I always go down the block and loosen and re-torque!! Nice to be sure!!
jniston here is the deal any shop that should go near your car should have at least torque limiter extensions these are color coded for the application easy to use and puts acceptable torque on a lug nut without over torqueing. If you want to be a lug nut yourself LOL just crank it on down on your alloy wheels. Results could be bad in the long run. I managed Firestone as service manager, worked as a registered BMW Mech and I used a torque wrench faithfully, you bet. and blah blah for another forty years of experience. Trying to set air guns is the wrong way to go big time. I know you mean well but this is a VERY SERIOUS CONSIDERATION FOR ANYONE DOING THIS SERVICE. Have a great day.
