-   -   Which oil plug washer should I use, choose from the PICTURES what you think is the 1 (https://www.hyundaiforum.com/forum/hyundai-accent-16/oil-plug-washer-should-i-use-choose-pictures-what-you-think-1-a-6912/)
thx1971 Aug 2, 2009 05:16 PM
Well I went out and got a new 14mm plug and some of the washer that people might use.
From left to right is
1.Factory Hyundai crush aluminum washer (the style that was giving me leaks)
2.A flexible plastic washer that came withe the new plug .
3. Nylon washer
4. Copper washer
http://i101.photobucket.com/albums/m...orVideo001.jpg
EricS Aug 2, 2009 06:18 PM
That's the one I've been using for the last 6 years without any leaks.
I put a brand new one every oil change.
NovaResource Aug 2, 2009 07:55 PM
In order of preference:
1. new OEM washer
2. nylon washer
3. copper washer
4. flexible plastic washer
thx1971 Aug 2, 2009 08:10 PM
I dont get it,when I use the OEM sometimes they leak and the leak wont stop until you get the sweet spot on tightness,for me its a hit and miss with the OEM then again I dont have atorgue wrench or the proper foot lbs to tighten it.I dont wrench down on the thing at all ,youcan kinda feel when to stop turning the wrench.
NovaResource Aug 3, 2009 06:23 AM
Are you using a new one every time?
thx1971 Aug 3, 2009 11:02 AM
Yes, i always buy a couple extra washers from hyundai when i do a oil change, .I just used my last one yesterday,.So i then put that blue plastic washer on and no leaks at all. Maybe on the next oil change i will use a hyundai washer since i have a new plug.
NovaResource Aug 3, 2009 11:56 AM
Maybe the washer isn't the problem. Maybe it was the plug or the pan itself. If the plastic washer is working then I'd stick with it until it stops working.
thx1971 Aug 3, 2009 12:07 PM
I ill keep an I on it and next oil change back tot he aluminum crush washer,
thank you all for the info and advice
