radio, clock, interior light
I have a 2001 accent 2 door hatchback. The clock, radio, and interior domelight died on this car. Is there a way to figure if these are all on the same fuse, or relay??? I have looked at both the fuse box in the engine compartment and the one on the driver's side kickboard near the clutch..... I have checked all the fuses and none seem shot. But I really couldn't find anything as far as a descriptionin either block refering to the clock or the interior dome light. One fuse in the engine compartment is marked "AUDIO" but it is not blown. Any help or guidence would be greatly appreciated!!
Thanks! Stephen |
RE: radio, clock, interior light
In the engine compartment, the fuse next to the AUDIO fuse is the ROOM LP fuse. That fuse controls the Audio (always-on memory), Instrument Cluster, Courtesy Lamps, Room Lamp (dome light), etc. Try that one.
http://www.hmaservice.com/GRAPHICS/e2/e2db301c1.gif http://www.hmaservice.com/GRAPHICS/e2/e2db301d1.gif |
AUDIO&ROOM LP FUSE
Whats the story with the little yellow plastic fuse doubler on theAUDIO and ROOM LP fuses how do you get the fuses out pull the whole thing or use tweezers to get out each fuse
RE: AUDIO&ROOM LP FUSE
its 2002 Accent by the way
Not sure what you mean; maybe a photo would help.
heres picture
[IMG]local://upfiles/672/3AE36EED867645B2B7042B002DDF1036.jpg[/IMG] |
another photo
Have you tried squeezing on the two sides of the yellow thing and seeing if the whole thing comes out with the fuses?
yes I tried that but it did give then I tried pushing them away the both times the whole fuse box was moving so I didnt want to put too much pressure to it
oops sorry I meant it didnt give when I messed with tabs
