-   -   Replaced 0xygen sensor in 2001 Accent L. Check engine light is still on. What to do? (https://www.hyundaiforum.com/forum/hyundai-accent-16/replaced-0xygen-sensor-2001-accent-l-check-engine-light-still-what-do-10331/)
pr0lab Feb 14, 2011 09:23 AM
I have a 2001 Hyundai Accent L with a 16 DOHC 4 cylinder engine. My check engine light came on a few months ago and I had the codes read. The codes were p0030 and p0133. They came up as being a possible bad oxygen sensor (front position before the catalytic converter) or a bad electrical connection. I purchased a Bosch OE Type sensor from auto zone, put it in, disconnect the battery to reset the check engine light, but after driving the car for 100 miles the light came back on. I had the codes read and the same codes came up. I took the O2 sensor back to auto zone and asked for a new one. They gave me a new Bosch OE type sensor and I installed it, but the light came on again. So I order an Hyundai OEM Factory Oxygen Sensor, installed it, and the same story. The check engine light came back on. In order to beat a dead horse i figured I would try a universal sensor. I bought a Denso 4 wire O2 sensor, installed it, cleaned and put electrical grease on the connections, but I am still getting the same codes. What in the world could possibly be wrong with my car. I took it to a ASE mechanic and he told me that my oxygen sensor was bad. I told him I already replaced it and he said that he would have to start by replacing it again and then figuring it from there. I have to pass emissions in 1 month. P.S. I also replaced my 2nd bank oxygen sensor with a factory OEM sensor from Hyundai. Any help or advice would be greatly appreciated!
sbr711 Feb 14, 2011 12:00 PM
This appear to be easy repiar --
0030,,,, heater circuit, replace B1S1
0133 ,,,, gots a cracked front pipe that has loud exhaust sounds under the front of car ?? --> Replace the front pipe and gaskets/nuts.. Chase it with program #52 also
pr0lab Feb 14, 2011 12:05 PM
I just replaces B1S1, and no noise under the car....
What else it might be?
sbr711 Feb 14, 2011 01:47 PM
Look for an exhaust leak... 99% of time we find crack at accordion for the front pipe.
Get it to where you can get ear close to it and listen, or feel for stream of hot exhaust gas coming out.
Maybe exhaust manifold crack, but that we do not see with Accent.
pr0lab Feb 14, 2011 05:22 PM
Thank you so much!!!!
What is the part number or link for this accordion pipe?
also what is the location of this pipe?
sbr711 Feb 14, 2011 07:48 PM
Read this topic,,,, and click on the link to the .pdf file and read it slowly...
the topic --> http://www.hyundai-forums.com/t59135...ms-at-once.htm
pr0lab Feb 14, 2011 08:09 PM
Thank you very much for all the help!
This was the best advice I ever got!
Nolopr Apr 26, 2011 12:07 PM
Fuel filter is usually located under the back seat...there is the fuel tank, fuel pump and the filter...Also check the vapor canister and the canister valve...they might be blocked...if the canister is not good it will send charcoal up and that's when it blocks the canister valve...Hope it helps..
