-   -   Timing belt replacement (https://www.hyundaiforum.com/forum/hyundai-accent-16/timing-belt-replacement-14030/)
fokker Nov 17, 2013 02:02 AM
Hi,
I am new here and need help from any one who can help,my accent 09, i need to change timing belt, engine died while driving,after inspection, timing belt tooth some missing, how and what to check ?:confused:
NovaResource Nov 18, 2013 08:40 AM
If the belt broke while driving, the pistons probably hit the valves and you will need major head work and possible a new engine. Go to a trained mechanic to have the engine checked. This is not a repair for a shadetree mechanic.
Example: https://www.hyundaiforum.com/forum/g...nt-valve-6630/
How many miles were on the belt?
Agucua Dec 21, 2013 07:20 AM
Your timing belt should be replaced every 50-70,000 miles. Carmakers have specified the replacement intervals for timing belts.
