-   -   Transmission/sensor problems? (https://www.hyundaiforum.com/forum/hyundai-accent-16/transmission-sensor-problems-4257/)
kelvis97 Apr 26, 2008 10:43 PM
I have a Hyundai Accent 2001, the "check engine" started to light a
few weeks ago and from previous experience
thought maybe the gas cap might be the problem.
My gas cap was missing, I went to a parts store bought a new one
and the light did not go off.
(This car has 124,000 miles and a great engine)
I decided to go to the garage were I usually have repairs done
for a oil change plus a scan of these codes.
The mechanic after scanning said there were two
problems:
Oxygen sensor and a transmission sensor, the transmission sensor
from what I understood could only be accessed by removing
the pan
this is the scan results from a scan
at AutoZone Parts Store:
Global ODBll
DTC ( Codes)
PO442
EVAP Emission
Control System Leak (Small)
PO133
O2 Sensor
CKT Slow response
(Bank 1 Sensor 1)
P1529
Manf Cntrl Veh. Spd.
Idle Speed Control
Auxiliary Outputs
PO717
Input/Turbine Speed
Sensor A
Circuit No Signal
DTC Pending (Codes)
No Faults detected
Wondering what to do here?
NovaResource Apr 27, 2008 07:44 AM
RE: Transmission/sensor problems?
P0442= this is probably a cracked and leaking rubber hose in the EVAP Emission
system. It's just a matter of finding it.Very common in older cars.
P0133 = this is just a matter of changing the O2 Sensor. Very common.
P1529andP0717 these two are probably internal trans sensors that need to be replaced by a mechanic.
None of these are surprising based on the age of the car.
