-   -   Troublecode Help... (https://www.hyundaiforum.com/forum/hyundai-accent-16/troublecode-help-4035/)
Jr1964 Mar 22, 2008 01:19 PM
Troublecode Help...
'02 Hyundai Accent, have 2 trouble codes...
1. P1522
2. P0722
Any help with code meaning and how to fix would
be appreciated.
_____________________________
Jim
ken99 Mar 22, 2008 02:20 PM
RE: Troublecode Help...
P0722 indicates a bad pulse generator in the transnission, a sensor that monitors rpm on the transfer shaft. I couldn't find a specific reference to P1522, but I suspect it is a general error code issued by the ECM when the TCM flagged the problem with the pulse generator. There are two technical service bulletins regarding the replacement of the PG-B, #03-40-016 and #03-40-022. Both can be found at http://www.hmaservice.com/ . 016 is specific to the 2000-2002 Accent. 022 covers a wider range of models. Replacing the pulse generator and reseting the codes should solve your problem.
retsam Mar 22, 2008 09:17 PM
Please don't go too fast for changing a sensor, Those 2 sensor (pulse Generator A & B) are connected on the same harness, connected with a cheap connector.
The best way it is to remove the battery and tha battery tray.
and clean that connector and add some electric grease.
I have remove PGA for fun and found out with a multimeter it was working correctly.
It was on my sister hyundai accent 2002.
And like Ken99 says you have a TSB on that.
It should not be more then 30min.
Have Fun.
