-   -   Weird Problem with fuel (https://www.hyundaiforum.com/forum/hyundai-accent-16/weird-problem-fuel-6436/)
soliosis May 27, 2009 12:17 PM
I drove in some negative degree weather after hitting a curb with some ice on the road. After the next day my Hyundai Accent car wouldn't start. I sprayed Ether in it to see if it was the engine, but it would tunr over and act like it would start if there was a continuous fuel source. I replaced the Fuel pump, but not the filter yet. I still doesn't start. Is there an automatic fuel line shut off that happened after I hit that curb? The check engine light went on after that and stayed on. I got one of those car scanner andit shows that nothing is wrong. I also bought a new relay for the fuel pump, but it also did nothing.... any recommendations... Thanks
ken99 May 27, 2009 02:04 PM
Yes, there is and the emergency fuel shutoff is discussed in the owner's manual to the car. Did the car run for any length of time after hitting the curb?
soliosis May 27, 2009 08:14 PM
Yeah
The car ran great... with no problems at all for a whole next day (60 miles). Where exactly is that part located? Or do you think it may be something else.
I am going to buy the repair manual on CD since it didn't come with an owners manual with the car.
soliosis May 27, 2009 08:20 PM
another perspective
He had something similar but not sure because OBDII codes not mentioned... a possibility
https://www.hyundaiforum.com/forum/s...ead.php?t=3943
ken99 May 27, 2009 10:30 PM
If the emergency fuel cutoff switch had been triggered, the car would not run at all, much less 60 more miles. It appears you have confirmed the engine is not getting fuel, but have you checked for spark. No fuel and no spark is a sign that either the crankshaft rotation sensor or camshaft rotation sensor has failed, the crankshaft sensor being the more common problem. Also, what year Accent do you have? I can find you a link to the owner's manual on the HMA service site. Actually, the HMA service site (http://www.hamservice.com/) has pretty much the whole service manual online if you are interested.
soliosis May 28, 2009 08:01 AM
spark
I know it has spark, because I sprayed ether (starting fluid) in it and it would run until the small amount of ether ran out that I sprayed.
soliosis May 28, 2009 08:03 AM
that link
That link went to a Japanese/Chinese website that I couldn't decipher... made me laugh a little.
ken99 May 28, 2009 08:14 AM
I have never said I could type worth squat. Try http://www.hmaservice.com/. The site is designed to work with IE. I would start checking fuses in both boxes. Could be the fuse providing power to the pump has blown.
soliosis May 28, 2009 08:38 AM
Yeah all my relays and fuses looked good - I actually bought a new relay for the fuel pump and installed it. But is there a fuse beyond the relay for the fuel pump - somewhere past the fuse box in the engine, possibly? Just want to make sure I am not missing anything or not seeing something. I know some cars can have weird setups.
soliosis Jul 9, 2009 05:15 PM
The Crankshaft sensor
I just want to thank you for your advice! The crankshaft sensor is the culprit.... :) I will now get my timing belt changed because I am almost at 60,000 miles.
Thanks
