08 accent wont start
Old 07-20-2017, 09:07 AM
Jason Biere's Avatar
Exclamation 08 accent wont start
my 08 accent won't start. it cranks but it wont start. it pulled a code. Engine coolant temperature sensor. I reset it. still wont start. no codes....
Please help anyone
Old 07-20-2017, 12:17 PM
avisitor's Avatar
Crank, no start
Engine coolant temperature sensor?
Check this video out ...
Anyway, back to basics ...
Check for spark at the plugs
When you first turn the key to the on position, do you hear the fuel pump prime the fuel rail?
Check to see if injectors are firing (listen at the injectors for clicks while cranking).
(Spark, fuel, air, exhaust, timing, compression, etc)
Old 07-21-2017, 12:54 PM
Exclamation wont start
still wont start, where do I find the temperature sensor and the timing sensor????
Old 07-21-2017, 08:30 PM
avisitor's Avatar
What have you done to test it/ troubleshoot the issue?
Did you check to see if there is spark at the plugs?
Did you listen to the fuel pump prime the fuel rail when the key is first turned to the on position?
The engine coolant temperature sensor should be near the crankshaft sensor.
Maybe if you google "hyundai Accent ECT"?? And look at images??
Timing is done by using the crankshaft sensor and/or camshaft sensor?
Sends signal to ECU. ECU determines when to fire spark and injectors.
Are you going to troubleshoot the problem by replacing parts??
Good Luck
kingofkingsvi
12-02-2008 03:54 PM
babysuri
04-05-2007 12:30 AM
justjoshin531
03-16-2007 03:10 AM
james1983
09-21-2006 11:27 AM
annettelindner
04-23-2006 04:31 PM
Quick Reply: 08 accent wont start
