Where Is The Oil Pan Drain Plug??
Old Aug 29, 2008 | 12:41 PM
Charlie1969's Avatar
Default Where Is The Oil Pan Drain Plug??
Yesterday, I was to change the oil inour 1.6 liter2007 Accent. I accidently drained the tranny; the pan looked just like an oil pan!
Anyway, I see two other plugs that look nothing likeany oil pan I've ever seenand want to be certain I get the correct one.
I believe it is on the passanger side,cast aluminum with cooling louvers in the bottom, close to being under the oil dipstick with the drainplug facing rear. Is that the oil pan?
Old Aug 29, 2008 | 12:53 PM
Default RE: Where Is The Oil Pan Drain Plug??
That sounds correct.
Part #5 is what you are looking for:
Old Aug 29, 2008 | 12:59 PM
Whoot! Thanks, man.
Old Aug 29, 2008 | 08:54 PM
ken99's Avatar
Did you pour what came out back into the transmission? or buy new transmission fluid? If this car has an automatic transmission, be aware that Hyundai uses a proprietary ATF called SP-III developed by Mitsubishi. Nothing else, including so called "universal fluids", are compatable.
Old Aug 30, 2008 | 12:31 AM
Doohickie's Avatar
Yep. It needs to be SP-III.
Old Dec 13, 2008 | 09:09 PM
korbynlehr's Avatar
Do you have a similar drawing for the transmission plug too you can post?
Old Dec 14, 2008 | 02:04 PM
Carnac the Magnificent isn't a member here. Please tell us what car, model year and transmission.
Old Dec 14, 2008 | 05:54 PM
korbynlehr's Avatar
Sorry about that. Mine is a 2009 Accent with manual transmission.
Old Dec 14, 2008 | 07:42 PM
2009 manual trans:
Fill plug:
Drain plug:
glassfern53
Sep 5, 2015 02:47 PM
turkishgold
Dec 31, 2009 02:40 PM
Jagson75
Jul 29, 2009 09:15 PM
thx1971
Jun 17, 2009 07:19 AM
danieleonharper
Mar 18, 2009 03:11 AM
