-   -   Windshield Washer Reservoir Replacement (https://www.hyundaiforum.com/forum/hyundai-accent-16/windshield-washer-reservoir-replacement-8868/)
atholon Aug 15, 2010 11:34 PM
Hi,
How are you supposed to remove the reservoir for windshield washer fluid? Mine has a crack in it and I need to replace it.
Thanks,
NovaResource Aug 16, 2010 07:32 AM
What year?
NovaResource Aug 16, 2010 07:43 AM
I checked your other post and I see you have a 2002. Next time, please tell us what year or any other important info so we don't need to search for it.
http://www.hmaservice.com/data/Passe...G/etdd345a.gif
REMOVAL AND INSTALLATION
1.Disconnect the negative(-) battery terminal.
2.Remove the front bumper cover. (see below)
3.Remove the washer hose and the washer motor connector.
4.Remove the washer reservoir after removing 2 bolts.
http://www.hmaservice.com/data/Passe...G/etdd008c.gif
5.Installation is the reverse of removal.
1.Loosen the head lamps, disconnect all connectors, and remove the head lamp.
http://www.hmaservice.com/data/Passe...G/ksdc211a.gif
2.Remove the 6 mounting clips on the upper bumper and 2 clips in the inner bumper.
http://www.hmaservice.com/data/Passe...G/ksdc211b.gif
3.Remove the mounting bolt and nut in the bumper side.
http://www.hmaservice.com/data/Passe...G/esdd211c.gif
4.Raise the vehicle, remove the clip and screw from the lower member, and remove the bumper cover.
http://www.hmaservice.com/data/Passe...G/esdd211h.gif
http://www.hmaservice.com/data/Passe...G/ksdc211d.gif
5.Remove the bumper stay.
http://www.hmaservice.com/data/Passe...G/ksdc211i.gif
6.Installation is the reverse of removal.
atholon Aug 21, 2010 07:35 PM
Hey, thanks for the instructions! It was an '02.
Luckily we didn't end up needing to take the bumper off. Once we got it jacked up the tire dropped down low enough that we could pull the resevoir out through the wheel-well.
olevet Dec 27, 2016 05:36 PM
New member here, Grand daughter has a 2015
Sonata what are the steps in changing the reservoir on it? Thanks
