-   -   Wiring Problems (https://www.hyundaiforum.com/forum/hyundai-accent-16/wiring-problems-20741/)
Marchello Nov 20, 2023 06:52 PM
Wiring Problems
Hello Everyone,
I have troubles finding the cause of the problem on my 2007 Hyundai Accent 3DR.
When I press the brake pedal, the rear defeoster indicator light on the dashboard comes on. After months, the symptom disappeared, because I have no brake lights at all.
I look at the wiring in the hatch area, cleaned the grounds but the problem is still there. I looked at the wiring schematic but have a hard time understanding it.
Could someone point me in a direction? I'm out of ideas.
Thanks in advance,
Marcell
hanky Nov 21, 2023 06:49 AM
You may need to get into the wiring harness that flexes every time you open and close the hatch.
If one of the wires in there has a break in it ,the circuit needing a good connection may be using another path.
