Put battery terminals on wrong way, won't start
i did the most stupid thing after recharging the battery
put it back the wrong way around now i read this is serious battery works but nothing happens when turn ignition clock stopped working also..? NO, !!!!!! help please, in £ debt already, i even have a spare engine for it no fuse inside gone, replace chunky ones outside/relays and pray? |
nice move, you've likely burned something out somewhere. hope you have a lot of hours to spend with a multimeter. try swapping the relays around - provided they are the same ones, many are - to see if you can get any change. with any luck its only a relay and this method will let you figure out which one(s)
| All times are GMT -5. The time now is 07:08 AM. |
