Hyundai Azera A Hyundai like you've never seen before.
Where the heck is the oil drain plug?
Old 03-06-2016, 01:58 PM
SkipII's Avatar
Default Where the heck is the oil drain plug?
Doing my wife's 2012 Azera. There is a 24mm bolt on the bottom of the engine case. Is that the drain plug? Sure doesn't look like one. I cannot find anything else that looks like an oil drain plug. There are usually angled and off to the side of the oil pan. This engine does not have a "pan" so much as just the engine casing.
Can anyone please help? I've got the car up on jacks!
Thanks.
Old 03-07-2016, 07:14 AM
avisitor's Avatar
Locate the oil filter and that should give you an idea of where the oil plug is located
Usually not right next to each other but close enough to see the relationship.
Never heard of an engine casing ... sounds like the transmission ATF plug???
Anyway, good luck changing your oil
Jagson75
07-29-2009 09:15 PM
thx1971
06-17-2009 07:19 AM
HyundaiCarProblem
03-21-2009 06:21 PM
danieleonharper
03-18-2009 03:11 AM
Charlie1969
12-14-2008 07:42 PM
Quick Reply: Where the heck is the oil drain plug?
