| jim4802 |
Dec 7, 2012 01:22 PM |
07 Azera CV axle removal
I have a 2007 azera 3.8L. I'm trying toget the pass side CV axle out, I have the rotor off, brakes, ball joint out of the way and there is a mounting braket about halfway that i took the bolts out of. Now where it is into the transmission, there is a aluminum ring that just pried off and I cant seem to see where to pry out the axle as it says you should do with Sonata's and other cars? under the aluminum ring looks like maybe a seal with like 6 tiny holes in it? still, i'm not seeing anywhere to hit with a pry bar or wedge to get the axle started coming out?? any help??
