2006 Azera 3.8L Spark Plug Replacement
What is involved in replacing the rear three spark plugs on my 3.8L 2006 Azera.
Removing the upper intake manifold (AKA surge tank):
INTAKE MANIFOLD 1.Disconnect AFS(A) and breather hose(B). 2.Remove air cleaner upper cover(D) and intake hose(C). https://www.hyundaitechinfo.com/data...G/kdrf173a.gif 3.Disconnect RH oxygen sensor connector(A). https://www.hyundaitechinfo.com/data...G/ucbf018a.gif 4.Disconnect RH injector connector(A) and ignition coil connector(B). https://www.hyundaitechinfo.com/data...G/kdrf153a.gif 5.Disconnect PCSV connector(A), MAP sensor connector(B) and PCSV hose. https://www.hyundaitechinfo.com/data...G/kdrf160a.gif 6.Disconnect ETC connector(A) and knock sensor connector(B). https://www.hyundaitechinfo.com/data...G/kdrf162a.gif 7.Disconnect water hoses(B) from ETC. 8.Disconnect PCV(C) hose. https://www.hyundaitechinfo.com/data...G/kdrf176a.gif 9.Disconnect brake vacuum hose. 10.Remove surge tank stay(A). https://www.hyundaitechinfo.com/data...G/ucbf020a.gif 11.Remove connector bracket(A) from surge tank. https://www.hyundaitechinfo.com/data...G/kdrf178a.gif 12.Remove surge tank(A). https://www.hyundaitechinfo.com/data...G/ucbf007a.gif |
4 Attachment(s)
Not hard,, get the upper plenum off and have at it.. just a handfull of bolts.
https://www.hyundaiforum.com/forum/a...1&d=1300234993 https://www.hyundaiforum.com/forum/a...1&d=1300234993 https://www.hyundaiforum.com/forum/a...1&d=1300234993 Install new NGK IRIDIUM only !! Tighten to 20lb-ft https://www.hyundaiforum.com/forum/a...1&d=1300234993 Out of NOVA' instructions..... #3 -- leave the sensors plugged in and attached to the bracket,, just remove the 1 bolt that hold bracket to plenum (#10).. #4 -- remove bracket from plenum, unplug coil lead, and take all 3 coil out with harness attached when time come. Skip #6 and #7 #8 -- remove the rubber hose for at top of throttle body, remove brake booster hose, and remove the bolt "A" at bottom of throttle body.. then remove the 3 bolts holding throttle body to plenum.. look at my pics as to how it should look. |
2006 Azera Spark Plug Replacement
Thanks so much for the information. The instructions were easy to follow - great!!!
FYI, my instructions are from Hyundai servcie website and are "by the book" but sbr711 is a Hyundai tech who does this on a daily basis. He knows the shortcuts so take his advice on making the job easier.
Billpetsch
When pulling the intake, should I replace the intake manifold gasket?
Yes, you should.
Thanks for providing the information for all of us. I am now ready to tackle the "spark plug" replacement on my Azera.
Great info, I'll have to change mine soon
I GIVE UP !!! How do I disconnect the AFS connector as shown in Step 1 ?? I have searched through both volumes of the Azera Factory Service Manual as well as looking through many posts on this forum but can't . There must be some sort of tab on the underside that must be depressed before the connector can be disengaged... but I can't find it. CAN ANYONE HELP !!! Thanks so much !
