-   Hyundai Azera (https://www.hyundaiforum.com/forum/hyundai-azera-40/)
-   -   2007 HYundai Azera 3.8 Axle Problem (https://www.hyundaiforum.com/forum/hyundai-azera-40/2007-hyundai-azera-3-8-axle-problem-14491/)
jckln Aug 4, 2014 10:55 AM
3 Attachment(s)
I had an accident with my 2007 Hyundai Azera 3.8 Limited at the driver's side a couple of weeks ago. The frame bent a little bit from the left side. Took it to bodyshop/mechanic and was straighthened back.
The mechanic adviced me to change the CV axle on the left side due to the CV boot coming off the axle. We bought a used CV axle from the junkyard and everything was fine until 2 days later when I made a wide left trun and I heard a cracking noise. Immediately, I pulled over and AGAIN the CV Boot from the CV axle has popped out of the axle again and up until now when i drive I hear a cracking noise when turning to the left. Even without checking the car again, the mechanic is still sauggesting its the axle I bought that I should buy another one
Please any idea of what I can do please. I've spend alot on this....Any effort will be appreciated
N:B - we also changed the hub in the process....before this problem occured
Here is the picture of how it looks now
NovaResource Aug 4, 2014 01:26 PM
That's what you get for buying a used, junkyard part. I'd suggest a new this time.
avisitor Oct 4, 2015 11:01 PM
Presently, the prices on new CV axles have come down considerably
And some places won't charge you a core deposit and may not require you to return the old part.
