-   Hyundai Azera (https://www.hyundaiforum.com/forum/hyundai-azera-40/)
-   -   Fuel Pump (https://www.hyundaiforum.com/forum/hyundai-azera-40/fuel-pump-17560/)
J Noah Choos Mar 12, 2019 11:48 PM
Fuel Pump
Hi,
Replaced fuel pump and filter in car with 153000 and get crank but no start. Bench tested pumps with both firing/working. Pumps never primed with key turned. Just wondering if it's a ground issue or possible ECU fault. Voltage to pump harness around 11V. Thanks!
avisitor Mar 13, 2019 06:48 PM
Check fuel pressure at injector rail..
Check for spark and injector pulse
hanky Mar 14, 2019 04:00 AM
In checking back by the pump, If you have power there (12 volts) coming in on the correct wire to the pump motor it should run. A good possibility, ground is either poor or absent altogether, Equally important as power or the circuit is not complete and cannot function.
