Hyundai Coupe The European version of the American Tirburon.
disc or drums
Old 03-10-2018, 06:01 AM
rizzeler's Avatar
Default disc or drums
hi on a 2007 hyundai coupe sIII does it have disc brakes on both front and back or just the front?
I can see brake calipers on rear wheels.
If disc brakes on both rear/front then is there such thing as a wheel cylinder on the rear?
Are wheel cylinders only on disc brakes.
Old 03-10-2018, 04:25 PM
avisitor's Avatar
Calipers are used on rotors or disc brakes
Wheel cylinders are used on drum brakes
Many times, when using discs or rotors for rear brakes, there is an emergency brake
Or parking brakes that uses the hat portion of the rotor as a drum
When that happens, there is a wheel cylinder used.
Sometimes instead of using a drum brake for the emergency brake or parking brakes
The caliper will have a lever connected to a cable going to the cabin parking brake lever
So it uses the disc brake as the parking brakes
ranger98
03-27-2010 07:25 PM
ddzc
04-11-2009 08:21 PM
69RocketJoe
07-10-2008 10:42 AM
92Vessel
08-07-2007 04:48 AM
mmbrady59
09-21-2006 04:21 PM
Quick Reply: disc or drums
