-   Hyundai Coupe (https://www.hyundaiforum.com/forum/hyundai-coupe-18/)
-   -   OVER RUN ? (https://www.hyundaiforum.com/forum/hyundai-coupe-18/over-run-1755/)
richie Sep 23, 2006 09:07 AM
OVER RUN ?
Got a 1.6 coupe,think its great.However it does seem to have over run ie when dipping the clutch to change gear the revs seem to hold before dropping slightly later even though the accelarator has been lifted.Have also noticed that sometimes when slowing down and depressing the clutch the revs seem to slightly increase momentarily.Anyone got similar problems or know the cause ?????
richie Oct 17, 2006 09:13 AM
RE: OVER RUN ?
Just got car back from its first service.Apparently the cause is a faulty throttle position sensor,which is now on order.Is mine the only car to have this problem??
blueboy_ju Oct 18, 2006 06:29 PM
RE: OVER RUN ?
no my 2.0 SE also seems to do the same, also mine idles too fast just below 2 on rev conter any ideas for me.
richie Oct 19, 2006 02:41 PM
RE: OVER RUN ?
I'm having the new sensor fitted tomorrow (Friday).I'll let you know if it makes the difference.
blueboy_ju Oct 19, 2006 04:43 PM
RE: OVER RUN ?
OK THANK U VERY MUCH I WILL KEEP LOOKING.
richie Nov 1, 2006 05:02 PM
RE: OVER RUN ?
Sorry about the delay in replying.
Had the new sensor fitted and it now runs sweet.Free Revving and no overrun.I'd get yours done if poss.
blueboy_ju Nov 7, 2006 03:39 PM
RE: OVER RUN ?
thanks for the info just dropped car off at garage lets hope it works on mine.
richie Sep 27, 2007 01:55 PM
RE: OVER RUN ?
Hi again
Did the garage solve your problem.I thought that it had solved mine but have since been experiencing the same problem.Mine seems to be holding the revs when I change gear,almost as if it were on choke.Sometimes when I accelarate hard,the engine seems to find a flat spot and does not accelarate smoothly ?
Doohickie Oct 1, 2007 02:33 PM
RE: OVER RUN ?
If the engine rpms do not drop right away when you take your foot off the accelerator, that's not a bug, it's a feature. The Idle Air Controller (IAC) purposely holds the rpms up when you suddenly lift off the pedal; letting the rpms drop suddenly can result in a rich mixture that polutes. By making the rpms hang a little, there is more complete combustion of the fuel for a cleaner burn and lower emissions.
Here is more info from another forum: http://www.elantraxd.com/forums/show...409&page=2
Here is a guy selling the plates for Elantras and Spectras (2.0L): http://www.elantraxd.com/forums/showthread.php?t=24364
And here is where the part is mounted on the engine (2.0L):
http://i42.photobucket.com/albums/e3...cture051-2.jpg
richie Oct 3, 2007 01:38 PM
RE: OVER RUN ?
Thanks for the suggestion,although the engine seems to have stooped holding the revs of its own accord (as it has in the past) and is now running sweetly.I'm a bit puzzled now as it has done this intermittently in the past,so would this suggest something sticking or possibly a fault somewhere ?
