01 elantra output speed sensor, plz help
HI Guys!
I just figured out what the problem was. it was output speed sensor on my 01 elantra... I don't want to spend a lot of money to fix it in dealer.. so I want to do it my self~ Can someone plaease let me know where the output speed sensor is?? I found input sensor from google. but I cannot find output speed sensor... If you have any picture of it, please show me.. I really need your help.. Thank you for reading...and hope U guys have fun with your rides :) |
output speed sensor
I just spent hours and hours putting these little sensors in and back out because the non hyundai brand replacement sensors don't seem to work... Anyway, the output speed sensor looks almost the same as the input, except the top where the wires plug into it is curved. It is located maybe 6-8 inches further back (toward the firewall). After the air filter housing is removed, look under the wiring harnesses alond the top of the transmission case.
Also, as a side note, it turned out my leaky radiator was causing my car to give me all the symtoms and codes for an output sensor(which i just wrote a post about)!! So, make cure you check the tranny fluid level and your cooling system for a problem... |
