05 Elantra Fuel Filter
If one changes the fuel filter, will that stop the problem I am having/?. My 00 Elantra will not allow me to fill the tank. At all station as I am pumping it will shut off. Its not the pumps or cap or air in tank.
More than likely you have a problem with your evaporative emissions system (gas tank vent). If the tank has been overfilled in thepast and liquid fuel has gotten up into the vent lines, it can cause those kinds of issues. There are some check valves and purge valves and stuff in the system that can be changed out as well.
The fuel filter should really have no effect on filling the tank though; the fuel doesn't go through the filter until it is pumped toward the engine.
2001accent
Sep 13, 2011 08:54 PM
bglick12
Jul 16, 2010 06:19 AM
