'06 limited rough/hard start
Gents,
When I try to start my wife's '06, it takes a little bit longer to start than in the past (used to take only 2 turns or so, now it takes 3 or 4). When it does finally ignite, it's a rough ignition and then it goes to normal. Any thoughts as to why this is happening? |
All the time or just after a gas refill?
Have the computer scanned for codes. |
Pretty much all the time during a cold start. A few guys at other forums mentioned spark plugs, and at 89,000 miles they have yet to be changed. I'll start with that.
Thanks. |
Sounds like your losing fuel pressure while the car sits. Verify by connecting fuel pressure gauge. Start car then shut off. Pressure should remain, if drops to 0 after shut off, your fuel pump is bad.
