2001 Elantra OBDII port/adapter
Have a friend with a check engine light on, Where is the OBD port and is it standard or where would I get an adapter to use my scanner ?
Thanks, Ted O. |
All OBD-II are standard and they are usually located under the dash by the steering column.
(Post 23557)
Originally Posted by Houndog101
(Post 23561)
Yes, I know that, where is it on the Elantra ?
(Post 23557)
(Post 23561)
There is a connector but, it is not the Standard OBDII connector,, if thats it where would I get an adapter ??"
http://www.hmaservice.com/data/PASSE...G/EJKB057A.gif Looks similar to this: http://chevythunder.com/OBD_II_terminal.jpg |
Thanks Bud, now you answered it... I am seeing the wrong connector.. I'm just a Ford guy trying to help a friend that just got this Elantra...;)
No problem. OBD-II is standard for all cars; GM, Ford, foreign, etc. The connector is the same and the codes are standardized. The original OBD has a different connector but all cars built after 1996-98 timeframe all use the same OBD-II.
As Nova already said it twice, all the OBDII connectors are all the same, or call it standard - 16 pins.
The Male connector is J1962-M. |
