-   -   2002 Elantra question on valve lifters (https://www.hyundaiforum.com/forum/hyundai-elantra-17/2002-elantra-question-valve-lifters-11622/)
petraman7 Oct 15, 2011 04:07 PM
I putting the head assby back on my 02 elantra and noticed that all of the lifters are the same except one. This one has a slightly recessed head and a round 1/2 " ( 12mm) detent in the center.
It's NOt from wear. It's way too symmetrical .
Anyone seen this before?
Thanks, Scott in Vermont
markmany Oct 31, 2011 03:38 PM
Can you post the pic of it? I can help you then.
petraman7 Nov 1, 2011 07:03 AM
Elantra lifter
It would seem that the "weird" lifter is actually the proper replacement for the original.
427troy Nov 15, 2019 05:59 PM
bad lifter
it is symmetrical, because it is wear. That's a bad lifter, and probably the cam lobe too. Replace the lifter and lash adjuster, adjusting the valve lash in the process. good luck.
