-   -   2003 Elentra VE - headlight issue. (https://www.hyundaiforum.com/forum/hyundai-elantra-17/2003-elentra-ve-headlight-issue-6420/)
ascensyon May 23, 2009 09:53 PM
I have a 2003 Hyundai Elantra VE (CDN version) and recently my highbeam on the passenger side stopped working, so I bought 1 new bulb (whatever you call it) and replaced the old one, but when testing it after installation it was not lighting up. So I thought it was defective, I brought it back to the store and got a new one, tried it same thing.
So now I'm wondering what to do next, is there a fuse linked to that specific highbeam connection that i could check? what is my next step to getting this working again?
jsinton May 24, 2009 03:51 AM
There's a high beam headlight relay in the fuse box under the hood. I'd try to replace that. If that doesn't work, then there's a short in the wires someplace.
ascensyon May 25, 2009 04:08 PM
Thank you for your help. I resolved the issue, it seems a mistake was done by me when re-inserting that awkward V pin bracket that holds the beam inplace. It's not only a bracket but a bridge also over to the ground.
I was installing it with the tip pointing towards the engine instead of the tip pointing and holding snug onto the light's metal plate.
TheWidowsSon May 25, 2009 05:21 PM
Those brackets are the biggest pains in the you know where.
