2003 Hyundai Elantra Rattling noise/seems weak
I have a 2003 Hyundai Elantra. I noticed lately that if I am in Drive, but holdin the brake there is a loud rattling noise. Also, when im accellerating the engine just feels like its strainging to go anywhere. No warnin lights have come on or anything.
Any ideas? |
RE: 2003 Hyundai Elantra Rattling noise/seems weak
could possibly be an engine mount going bad. does this only happen in drive or reverse? doesthe carshake any other times?
It pretty much goes away if i put it in Neutral or Reverse. Its really only when Im in drive.
what you can do is put the car in drive or reverse then with your left foot on the brake, parking brake on, step on the gas for as if you're accelerating and have an assistant look at the engine to see if it moves excessively. that will tell you which mount is bad.
I noticed that it does it in Reverse and in Drive.
Would a bad engine mount affect how the car feels when Im driving aka the engine strain im feeling? |
no i don't think so. that normally depends on engine and transmission performance.
Then what I would do is, with the car running and in drive. Put the emergency brake on and try to locate where the noise is coming from. It could just possibly be something loose or a shield of some sort vibrating against something.
true that, Italian Guy https://www.hyundaiforum.com/micons/m9.gif
yeah make sure you have an assistant https://www.hyundaiforum.com/micons/m9.gif
Thanks MadIndian1. Just tryin to assist everyone assisting other's. You have been a great help. Thanks and good luck with your diagnosing TheHamer. :)
