2004 Elantra, 70K Miles, Squeeking from Front Axle, Steering Wheel Shakes over 60
It began with a loud squeak from the front axle when going in reverse.
Now there's a noticeable squeak from the front right tire at most speeds, except when braking. And the steering wheel violently shakes at speeds over 60MPH. Is this a problem with bearings? Something else? |
it could very well be the bearing yes. i just had to do my passenger front bearing.
If you find out that the bearing is OK, it could very well be a bent rim wobbling at highway speeds. Most tire shops can't fix that, you need to find one that has a Hunter machine; they do high-speed balancing.
| All times are GMT -5. The time now is 05:49 AM. |
