RKramkowski |
02-20-2017 04:43 PM |
2005 Elantra won't start after overheating
Hi my 2005 Elantra overheated and blew a head gasket. Took it all apart, had everything checked. Head is good although I had to replace a broken valve. Cylinder walls looked OK but didn't remove any pistons. Put on a new head gasket, torqued to spec. Also changed the water pump and timing belt since I had it apart. Timing looks OK. Compression is a pretty consistent 120-125 psi in all cylinders. Given that the car has 185k miles on it, that wasn't much of a concern since it was consistent. Also replaced radiator (old one split), thermostat, hoses, wires, plugs, and belts. Did NOT replace coils or injectors. The car has spark and after cranking for awhile I do smell fuel so I assume it's getting fuel. I can hear the fuel pump start when I turn the key. It was running fine before it overheated. Now it just spins. No ignition whatsoever. It cranks just like what I'd expect for no spark or no fuel - but it seems to have both. What can I check to figure out what's going on?
