2006 Hyundai Elantra fuel filter location
Can anyone tell me where the fuel filter is located on a 2006 Elantra? Also, my check engine light is blinking, and my car is having low rpm issues. At times, the car dies, and then it will turn over, but not start. Anyone have any ideas?
Does the fuel tank have to be dropped to change the fuel filter and/or pump?
I suspect you may have a failing crankshaft rotation sensor (which cuts off both fuel and spark to the engine when not functioning). A good scanner will pull the code(s) and run diagnostics on the sensor as well.
PS: Does the fuel tank have to be dropped to change the fuel filter and/or pump?
