arhhyundaiEL |
11-28-2015 01:00 PM |
2007 hyundia elantra limited knocking sound left rear tire
Last month I started hearing squeaking noises and knocking noise coming from the left rear tire area(right rear if facing the trunk) when ever i hit ANY kind of bump, pot hole, etc. If i had enough people in the car it would make only the squeaking noise even at a dead stop. I decided to get out of the car to see if i could find where the squeaking was coming from and I noticed that whenever i pushed a slight bit on the shock the squeaking would stop. I decided that the problem must be coming from my shocks or shock mounts so I put in new shocks and mounts. After putting in new shocks and mounts the squeaking stop but the knocking did not go away. I'm pretty positive I did everything correctly in putting in the new stuff. Like i said, it only make a knocking noise when i hit anything that makes my car bounce up and down. I'll try to record some of the sounds and see what you guys think. So, what could causing the noise??
