98 Elantra, no turn signals
Hello!
I drive a 98 Elantra and my turn signals and indicator lights went out. I've got a new combo switch but I'm not sure how to install it/put it in. Does anyone know where it is located and/or how to put a new one in? Thanks! |
RE: 98 Elantra, no turn signals
Especially if your backup lights are out as well, check Fuse 9 in the passenger compartment fuse box.
to replace the switch you will have to remove the screws under the steering wheel, then remove the cover, unplug the harness connector, then remove screws holding multifunction switch. hope it helps if you didn't do already.
