Anyone still have a '91/92/93/94/95 or 96/97/98?
If you still have 91, 92, 93, 94, 95 (gen 1) or 96 or 97 or 98 (the gen 2), could you let me know?
I was hoping someone could look at their OBD-I port for me on their 91-95 and let me know which pins are populated in that 12-pin OBD port. And what the wire colors and tracer stripes are on each wired pin. Or, if you have a 96-98, could you look at that 16-pin OBD-II port, and let me know which pins are populated? The 12-pin should look like this: There should be two slots on the top row separated by 2 empty spaces then 3 more slots, and have 6 slots on the bottom row. 1 2 empty slot empty slot 3 4 5 6 7 8 9 10 11 12 Thanks. |
Correction, the 12-pin OBD-I connector should look like this:
5 4 empty slot empty slot 3 2 1 12 11 10 9 8 7 6 There should be two terminals on the top row separated by 2 empty spaces then 3 more terminals, and have 6 terminals on the bottom row. (Pins 10 & 9 should be under the 2 empty slots, respectively, and pin 8 should be under pin 3 and pin 7 should be under pin 2 and pin 6 should be under pin 1. I say this in case the forum editor tool looses the formatting I keyed in.) |
I'm still looking for anyone who still has a '91-'95 and '96-'98 Elantra who can check a couple pins for me on their OBD-I 12-pin data link connector and/or OBD-II 16-pin DLC.
Bump.
Still looking for anyone who has a '91-'95 and/or '96-'98 Elantra who can check a couple pins for me on their OBD-I 12-pin data link connector and/or OBD-II 16-pin DLC. |
