Both FOBs not working
Cant see both FOBS going bad at same time, good spare in house, etc
Fuse box yellow is set to ON Can anyone offer any good advise what to check ? Thanks much |
It will only start if you hold key up to push button switch, no other functions on FOB working
If you have no way of checking the batteries in the FOBs , why not try replacing the battery in one of them and see what you get ?
Had a similar problem and found the batteries and contacts corroded. But I live in high humidity Florida so we live with that problem. I used a little dielectric grease on the contacts when I installed the new batteries to prevent the problem in the future.
