cabin filter replacement directions
Hi
Could somebody give me stepby step instuctions on how to change the cabin filter on a 2001 hyundai elantra GLS-Thanks in advance. |
Here is the video instruction :
1. Open the glove box and remove the 2 rubber stop blocks from each side of the glove box.
2. First pull the stop block toward you (1). Then pull the front edge in toward the inside of the glove box and pull it out to remove it (2). https://www.hyundaitechinfo.com/file...3/0497001a.gif 3. Remove the glove box damper by gently pulling the mounting pin out, then feed the mounting pin through the hole. Hold/support the glove box to prevent it from swinging wide open when the damper is removed. Lower the glove box. https://www.hyundaitechinfo.com/file...3/0497001b.gif 4. Remove the 2 screws that hold the metal bracket at the back of the glove box housing. Lower the bracket out of the way. https://www.hyundaitechinfo.com/file...3/0497001c.gif 5. Push up and simultaneously pull towards you the two (2) filter cover tabs. The lower edge will pop out, slide the cover down to separate the cover from the three upper retaining slots. https://www.hyundaitechinfo.com/file...3/0497001g.gif 6. Pull out the old filter and/or slide in the new air filter P/N 97133-2D000 with the arrow facing in the direction of airflow (down in this case). https://www.hyundaitechinfo.com/file...3/0497001h.gif 7. Reinstall the filter cover. 8. Reinstall the metal bracket. 9. Reconnect the damper and rubber stops. |
