CASTROL TQ-D
Hello, i am just curious if this ATF is compatible with Elantra Gearbox.
The service center (I'mfrom Malaysia)i go to used this ATF for my car during my 40,000km service. http://www.castrol.com/castrol/secti...tentId=6005713 Cheers. |
RE: CASTROL TQ-D
The spec sheet states that it would be sufficient to use. I'd still check with your local dealer or parts store to be sure. Nearly any auto parts store can look up your make/model and tell you what fluids are required or recommended for use in your vehicle.
RE: CASTROL TQ-D
The required Fluid is CASTROL ATF+3 or QUAKER STATE + 3 or if you can afford it you use AMSOIL ATF this is compatable with all electronic transmission.
