Check Engine Light ON
Old Jul 9, 2017 | 03:02 PM
Obed's Avatar
Default Check Engine Light ON
Hyundai Elantra diagnosed as EVAPORATIVE EMISSION CONTROL SYSTEM--INCORRECT, FLOW DETECTED. Code P0441
Help understand this statement please
Old Jul 10, 2017 | 12:27 AM
avisitor's Avatar
Gas goes into the gas tank via the filler neck
It can be pumped out to the fuel rail for the engine to use
Vapors are vented out of the gas tank and through a carbon charcoal canister and vent valve
Hydrocarbons are stored in canister (clean air is released)
When engine conditions are right, purge valve opens
and hydrocarbons are pulled out of the canister then into the intake of the engine
Example: Incorrect flow could mean the purge valve is not opening so there is incorrect flow
Or a number of other things.
Presently I am still working on my own P0440.
Good luck to you
jordanwake
Feb 6, 2011 08:13 AM
duude1
Feb 3, 2006 06:04 PM
mlowe
Dec 23, 2005 02:48 PM
Lydia1
Nov 1, 2005 09:45 PM
tomholl
Jul 28, 2005 12:53 AM
