Corrosion on Cylinder 1 coil output!
I checked the coil thorougly and 2, 3 and 4 on the coil output were the plugwire connects were clean. However, the #1 was corroded. Any Ideas?
RE: Corrosion on Cylinder 1 coil output!
i would just clean it, try to install some di-electric grease to prevent the corrosion next time.
I did do that and I also cleaned the entire coil pack because, it had oil residual all over it from the valve covers leaking. I am just gonna go ahead and replace it because, it still ran rough after. I am actually just gonna buy everything new, to be safe. What brand do you recommend?
remember try dealer parts especially plug wires.
Yes, i'll do just that. Thanks again.
| All times are GMT -5. The time now is 02:54 AM. |
