Crank Position Sensor replaced....
But I still have stall issues. I thought about it and I now realize that my problem has gotten worse and worse. At first it would stall, then after a few moments it would start and the problems would dissapear for a long while. As time passed though, the stalling would become more frequent. Now I can barely go about 5-8 minutes before a stall. I'm getting tired of walking. The CPS has been changed twice with no improvement. Someone mentioned that there is a magnet attached to the end of the cam shaft that could fall off and not rotate to indicate the cam shaft is rotating. Has anyone taken off the valve cover to see what the cam shaft looks like? Is there an actual magnet or something that would signal while rotating?
Originally Posted by twowheelinjim
(Post 25692)
http://www.hmaservice.com/data/Passe...G/EFDA301E.gif http://www.hmaservice.com/data/Passe...G/EFDA701E.gif Which one have you repeatedly replaced? The camshaft position sensor (CMP) or crankshaft position sensor (CKP)? Also, when the engines stalls and fails to restart, does the engine have spark and/or fuel? There are lots of things that can cause stalling besides these sensors. |
I'm having difficulties with my crank position sensor, is it easy to replace?, can it be done the DIY way or do i need to bring it to a garage?
It does not have one per say. The crank sensor is part of the distributor, should be replaced as a complete assembly.
Originally Posted by Bousexemo
(Post 26492)
Originally Posted by archebald23
(Post 26492)
CRANKSHAFT POSITION SENSOR (CKP SENSOR) The crankshaft position sensor, consisted of a magnet and coil, is located next to flywheel. The voltage signal from this crankshaft position sensor is relayed to the ECM to indicate engine RPM and the position of the crankshaft. http://www.hmaservice.com/data/PASSE...G/kfpd701e.gif |
